Ini fail/300zx
Discussions related to Nissan DataScan I software (NDSI) for Android
Mr300
Ini fail/300zx
Post by Mr300 »
I recently purchased the Nissan Consult Bluetooth 14 pin del and Nissan data scan i. I am using this on my kindle fire. The app will open pair and connect but then i get the common ini failure. How is this fixed or how do I get it to function properly?
R.J. Bijsterbosch
Re: Ini fail/300zx
Post by R.J. Bijsterbosch »
You need to do the wire fix then it will work. I had the same problem. The most of the adapters have a production fault, therefore the adapter will not work. The wire fix will solve the problem.
See link below.
download/file.php?id=163&sid=4c665bb3cd ... 5ebe260440
OwnerCS
Re: Ini fail/300zx
Post by OwnerCS »
What year is your car?
R.J. Bijsterbosch
Re: Ini fail/300zx
My skyline is from 1993 with a Z32 ECU with Nistune. Z32 ECU partnumber: 23710-41P03
Jason
Re: Ini fail/300zx
Post by Jason »
Most probably the adapter you are using doesn't generate the clock signal. This older ECUs require the clock signal to initiate connection.
It could be that the adapter you are using was never design to generate the clock signal or you might have to do the white wire fix as posted before.
seb.racing
Re: Ini fail/300zx
Post by seb.racing »
same problem on a 300zx of year 1996
seb.racing
Re: Ini fail/300zx
> See link below.
> http://home.exetel.com.au/nds/phpBB3/download/file.php?id=163&sid=4c665bb3cd360f9d2da99f5ebe260440
You know the modification for a Nisbie interface?
http://www.image-heberg.fr/files/1521365860172083935.jpg
