Page 1 of 4
ini failed
Posted: 24 Jan 2016, 18:04
by mastrZ
just got my bluetooth adapter from the recommended uk supplier..
I have a Droid turbo x running on the 5.1
plugged the BT adapter in..
paired to it..
opened up NDSI for the android, connected to the HC-05 adapter..
says connected, but immediately has a status of: ini failed
any thoughts or help here would be great! really looking forward to utilizing this daily.
thanks in advance,
-Matt
Re: ini failed
Posted: 25 Jan 2016, 23:22
by Jason
Check if you are getting the clock signal on the adapter CLK pin. It should be reading about 154kHz.
If you are not getting anything return it to the supplier or fix it.
Re: ini failed
Posted: 27 Jan 2016, 11:03
by Jason
Fix from the supplier looks like the attached pic. It's the white wire.
A PCB fix will be implemented in the next production run.
Re: ini failed
Posted: 09 Feb 2016, 21:45
by zitko
Hello, I got "mini ELM327 v1.5 OBDII Bluetooth Adapter". On my phone I also install NDSI LITE app. When I try to connect via app to the adapter, every time drop the connection status in app "ini failed". What can be a issue
Re: ini failed
Posted: 10 Feb 2016, 00:14
by amdeleon23
Im also getting this but im using the ftdi usb. Can anyone help us address this problem? I really need to use this thanks.
Re: ini failed
Posted: 11 Feb 2016, 14:32
NDSI app is not designed to work with ELM327 Bluetooth adapters. Try NDSII or NDSIII depending on the model of your car.
Re: ini failed
Posted: 26 Feb 2016, 21:18
by niko99
I am trying to connect to my nissan almera n15 (ga16de) with the bluetooth adapter (not DIY)
but I get the "Ini failed" message...
Any suggestions how can I fix this :[?
Re: ini failed
Posted: 29 Feb 2016, 11:13
niko99 wrote:
> Hi,
> adapter (not DIY)
What adapter are you using?
Re: ini failed
Posted: 05 Mar 2016, 05:57
by niko99
What detail do you need exactly?
It looks like this one:
http://home.exetel.com.au/nds/NDSIA/pic ... 67x363.jpg
Re: ini failed
Posted: 11 Mar 2016, 19:26
by niko99
Anyone
