Morning all,
I'm new here and want to get some guidance.
I wanted to know which of OBD devices can be used on a Nissan Terrano II build in year 1996. It is an Diesel with an TD27 Engine with PR 50 body. Underneath the dash I find a optional OBD plug with 14 pins. Think it's the first designs.
and the car is made in Japan. What I can find is the 14 pin connector with one nearby connector that I'm not aware off. (see attached pictures)
Could someone help me identify which ODB the best can and will work on this car
Hope to get some results with ODB scan tool. Specifically, the package that needs to work with this type.
Please feel free to mail me with results or advice.
Panday
Info request on Nissan terrano
- IMG_20170619_192842.jpg (81.5 KiB) Viewed 4129 times
- IMG_20170619_192148.jpg (47 KiB) Viewed 4131 times
Re: Info request on Nissan terrano
The connector on the right and the bottom picture is your DDL1 diagnostic connector.
You can use our NDSI software with this connector.You will need a Consult I adapter cable to connect to the ECU. See our website for supported and tested adapters http://home.exetel.com.au/nds/NDSI/inde ... edadaptors
