Ini File fails to upload
Discussions related to Nissan DataScan II software (NDSII) for Android
maxkarton
Post by maxkarton » 10 Jan 2018, 18:54
I am trying to get the Lite version of the software to connect to the ECU. I can connect to the Bluetooth adapter but not the ECU. It comes up with an "ini fail" error. I am using on one of the supported adapters from eBay. It is reporting via the software ELM v1.5. Any ideas?
maxkarton
Re: Ini File fails to upload
Post by maxkarton » 10 Jan 2018, 18:56
Couple of things I forgot to mention. I have a 2001 GU Patrol 4.8. And the PC version of the software works.
Post by Tom » 24 Jan 2018, 12:10
If the NDSII Windows PC software works, the NDSII app should work as well. Most probably it's an adapter issue.
Can you capture the debug log and send it to nissandatascan@yahoo.com.
maxkarton
Post by maxkarton » 03 Feb 2018, 17:26
HI Tom, I will send the log. I have tried another adapter and got the same issue. Cheers. Mark
